Bold Reedsprite
Posts : 29 Jewels : 127110 Character Rank : Z-rank Character Magic : Arc of Embodiment Guild : Magic Council Join date : 2015-08-15
 | Subject: Bold's Plotter Sun Aug 16, 2015 11:01 am | |
|  | Characters of Interest: Simply put, any being that Bold believes to be a good fit into the Legendary Story that he wishes to experience first hand, one way or another. This character must not be pure of intent such as totally "good" or "evil". However, don't count yourself out just yet. Bold himself doesn't quite believe that anyone is black and white in personality and intent. There is always an in-between that Bold may end up exploiting in order to create his story.
Characters of Disinterest: You don't want to be on this list. Bold will actually attempt to "erase" you from the story he wishes to compose if and only if you are a hindrance in anyway. Mostly just "character killers" that kill too early in the story or persons that are "party poopers". However, just because you are not within the "of Interest" list does not mean you will be automatically placed within the "of Disinterest" list. The two lists aren't perfect opposites.
Others: In general, anyone not categorized into the above lists. There are those "bystanders" that are there for imagery such as the person in a crowd of random people or the waiter in a restaurant. Obviously not every little person ever mentioned, just characters that Bold has met and wishes to think upon in a later date for possible categorization. Whoever Bold meets IC will be put on this list to begin with.
- Spells:
- Code:
[b]SPELL NAME:[/b] Spacial Rift of Hyper-Dimensional Travel [b]RANK:[/b] A [b]DESCRIPTION:[/b] The caster creates a spacial rift which teleports the caster up to 30 meters away from their original position. For the rest of the post after the teleportation, the caster is unable to attack. [b]DURATION/COOLDOWN[/b] 1 post/2 posts
[b]SPELL NAME:[/b] Tengu King's Windy Wrath [b]RANK:[/b] S [b]DESCRIPTION:[/b] The caster creates an expanding sphere of wind around himself which deals S-rank slashing damage to whatever comes into contact with it. The sphere of wind expands from 1 meter around the caster up to 30 meters away at 35 m/s. [b]DURATION/COOLDOWN[/b] 1 post/3 posts
[b]SPELL NAME:[/b] Legendary Tengu Beast of Mythology [b]RANK:[/b] Z [b]DESCRIPTION:[/b] The caster creates a strange, living, 40 meter large, golden Tengu Beast with wings and a humanoid/avian physique. The monstrous beast is capable of dealing Z-rank physical damage and fly at a speed of 40 m/s. Those unprepared to be hit by the Tengu Beast experience a knockback of 30 meters. It takes a total of Z-rank damage to destroy the Tengu Beast. Looks like this - [url=http://illiweb.com/fa/pbucket.gif]Link[/url] [b]DURATION/COOLDOWN[/b] Until Destroyed/6 posts
- Items:
- Code:
[b]ITEM:[/b] Arms of the Shining Believer [b]RANK:[/b] Z [b]DESCRIPTION:[/b] Using a special trick in order to create a permanent creation using his Arc of Embodiment, Bold created a 1 meter diameter ring of a golden hue that has three arms attached to it. The ring of arms floats behind Bold and acts like an extension to Bold's body, moving as if physically attached to Bold. The ring and arms can spin/move up to 40 m/s with the same strength as Bold's arms. The ring of arms itself possesses the capability to heal a single target that it is touching up to Z-rank damage as long as, for the duration of 1 post, the target does not move from their general position and is not attacked (same goes for the ring of arms). Looks like this - [url=http://illiweb.com/fa/pbucket.gif]Link[/url]. [b]DURATION/COOLDOWN[/b] 1 post/4 posts
[b]ITEM:[/b] Gram [b]RANK:[/b] Z [b]DESCRIPTION:[/b] Gram is a perfect replica created using a special Arc of Embodiment trick. It is a 7 foot long, golden greatsword. The original sword, also named Gram, is THE sword of the Magic Council. It has the destructive potential of the Etherion Cannon which is why it was sealed away with the only key belonging to none other than Bold Reedsprite, the Rune Knight in charge of protecting it. Anyway, what makes Gram so powerful is its ability - the moment that Gram is unsheathed, it has D-rank power. Hold on, it gets better! With every post that Gram is unsheathed, it doubles in power (D to C, C to B, etc~) which gives it the potential of surpassing Z-rank power, given enough time. However, when Gram successfully strikes with power exceeding Z-rank, it forcibly sheathes itself and becomes unusable for a certain duration. Being a perfect replica, Gram (this item) also has this incredible power. Looks like this - [url=http://illiweb.com/fa/pbucket.gif~original]Link[/url] [b]DURATION/COOLDOWN:[/b] Until Sheathed/4 posts
